1988 Isuzu starting trouble
Old Dec 20, 2005 | 02:15 PM
Zebagor's Avatar
Hello can anyone help me please. i have a 1988 Isuzu tropper 2 4X4 4 cl. i
am having trouble starting it. it died when i was driving it and had to
have it towe to my place and ever sence it wont start. there is no gas
getting to the engine. have changed the fuel filter and the fuel pump
fius and i checked the gas tank the gas is comming out but dont no wy
it wont reach the engine every thing seams ok nothing wrong. i also
tryed that starting fluid in a can thing it did start it but any temp
to hit the gas peddel it stalls. it stalls after the starter fluid is
gone. any help would be great.
Edited by: Zebagor
Old Dec 22, 2005 | 02:33 PM
Patrick's Avatar
Super Moderator
does it have a leak somewhere??
Old Dec 28, 2005 | 04:25 PM
ISUZUGURU's Avatar
Super Moderator
ITS NOT GETTING FUEL IS IT FUEL INJECTED? CANT REMEMBER THAT YRS WAS AN OPTION.IF SO IT MAY NOT BE MAKING ENOUGH VOLUME OF FUEL IT SHOULD HAVE 50PSI OF PSI.RUNS OFF OF CARB CLEANER BUT NOT ITS OWN FUEL,ITS A FUEL DELIVERY PROBLEM,ALSO THE QUALITY OF FUEL,DID YOU GET BAD GAS ? DID YOU RECENLTY GET FUEL BEFORE IT DIED?ALSO THE ALTERNATOR CONTROLS POWER TO THE FUEL PUMP IF ITS ELEC.CHECK THE ALTERNATOR FOR CHARGING.IT ALSO RUNS THE BLOWER MOTOR INSIDE THE VEHICLE.GET IT TO RUN AN TURN YOUR HEAT ON DOES THE FAN RUN? DOES THE BRAKE AN BATTERY LIGHT COME ON AN STAY ON WHEN YOU GET IT TO RUN...OH AN BE CAREFUL WITH STARTING FLUID....DOES MORE DAMAGE THAN GOOD,GET A CAN OF CARB CLEANER FOR YOUR DIAGNOSIS.
KingOMeat
Dec 11, 2011 03:25 PM
rgarcia
Feb 19, 2009 11:45 AM
dpotgieter
I-Mark
Apr 27, 2008 09:20 PM
1TLB
Feb 24, 2008 12:16 PM
amcmb1968
Jun 24, 2007 08:01 PM
