Hello can anyone help me please. i have a 1988 Isuzu tropper 2 4X4 4 cl. i am having trouble starting it. it died when i was driving it and had to have it towe to my place and ever sence it wont start. there is no gas getting to the engine. have changed the fuel filter and the fuel pump fius and i checked the gas tank the gas is comming out but dont no wy it wont reach the engine every thing seams ok nothing wrong. i also tryed that starting fluid in a can thing it did start it but any temp to hit the gas peddel it stalls. it stalls after the starter fluid is gone. any help would be great. Edited by: Zebagor |
does it have a leak somewhere??
ITS NOT GETTING FUEL IS IT FUEL INJECTED? CANT REMEMBER THAT YRS WAS AN OPTION.IF SO IT MAY NOT BE MAKING ENOUGH VOLUME OF FUEL IT SHOULD HAVE 50PSI OF PSI.RUNS OFF OF CARB CLEANER BUT NOT ITS OWN FUEL,ITS A FUEL DELIVERY PROBLEM,ALSO THE QUALITY OF FUEL,DID YOU GET BAD GAS ? DID YOU RECENLTY GET FUEL BEFORE IT DIED?ALSO THE ALTERNATOR CONTROLS POWER TO THE FUEL PUMP IF ITS ELEC.CHECK THE ALTERNATOR FOR CHARGING.IT ALSO RUNS THE BLOWER MOTOR INSIDE THE VEHICLE.GET IT TO RUN AN TURN YOUR HEAT ON DOES THE FAN RUN? DOES THE BRAKE AN BATTERY LIGHT COME ON AN STAY ON WHEN YOU GET IT TO RUN...OH AN BE CAREFUL WITH STARTING FLUID....DOES MORE DAMAGE THAN GOOD,GET A CAN OF CARB CLEANER FOR YOUR DIAGNOSIS. |
