Number 4 cylinder misfire???
Old Feb 2, 2009 | 10:29 AM
marine6132's Avatar
Hello, I have a 98 Amigo 4x4 4cyl. 5 speed. I''m having problems with my engine and have a check engine light on. I went to advance and they checked it and stated that the number 4 cylinder misfire. I had just put new plugs and wires on a year ago. Also I just put in a bottle of injector cleaner in. I''ts funny that when I first crank the engine it idles fine but when you start going forward it acts as if its not getting fuel, but as I run it longer and the engine warms up it operates better. I checked the plugs ang they don''t look fouled. Advane says to replace the wires but I already did that a year ago. Also Advance stated that if the coil was bad it wouldn''t run at all. Has any one had this problem. Thanks for any ideas.
Longboard1st
Axiom
Dec 12, 2017 03:36 PM
christennn
Oct 21, 2011 02:26 AM
JimmyK
Nov 26, 2008 01:21 AM
Raihnman
Oct 31, 2008 01:40 PM
NJMAN
Nov 14, 2006 10:42 PM
