Computer and Fuel Systems Talk about the control module, fuel systems and delivery, customization and more...
DIY: Scanning With An OBD 2 Code Reader (Video)
Old Dec 11, 2011 | 04:05 PM
ProStreetDriver's Avatar
Default DIY: Scanning With An OBD 2 Code Reader (Video)
How to scan your vehicle with a generic OBD II code reader to diagnose the check engine light (CEL). How the code reader operates may vary between makes and models. OBD II was used on vehicles in the mid 1990s and newer. Before OBD II was the OBD I system which needs a specific reader for each vehicle.
Once the code is found, a simple internet search using your vehicle's make, model, and the code found will allow you to search what caused the issue, and what can be done to solve the problem. The internet search allows you to search the online database through car forums, online manuals, etc to help solve the issue.
If you have solved the issue causing the fault code and the vehicle does not clear the fault code, you may need to clear the code using a code reader. Or if you hate seeing the check engine light then you can clear it, but if the problem persists, you will need to fix the issue.
ProStreetDriver
Detailing
Sep 17, 2020 07:55 AM
ProStreetDriver
Detailing
Apr 7, 2012 04:24 PM
gaillarry
Sep 14, 2011 04:22 AM
ProStreetDriver
Wheels and Tires
Jul 4, 2011 05:07 PM
1goindiesel
Dec 2, 2010 12:51 AM
