Towing/Wiring question
Old Aug 20, 2008 | 06:36 PM
Tony916's Avatar
Hello!
I bought a trailer and all the necessary wires to light up the trailer properly. Also, I went and bought the little connector that should come from the car to trailer to plug it up, but Im kinda stuck. Where would I connect/splice the wires to coming from the car? Has anybody towed with their Axiom that installed their own wiring? Can anyone help me?
Old Sep 10, 2008 | 03:52 PM
Tony916's Avatar
Anyone?
Old Sep 11, 2008 | 07:37 PM
JLEMOND's Avatar
Originally Posted by Tony916
Anyone?
YOUR AXIOM SHOULD HAVE THE TRAILER HARNESS WHICH IS PREWIRED THE SAME AS THE RODEO, SAME PART , IN THE LEFT REAR CARGO AREA , BEHIND THE PANEL, YOUR ADAPTER SHOULD PLUG RIGHT IN IF IT IS THE CORRECT ONE, JERRY
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Sep 12, 2008 | 02:29 PM
Tony916's Avatar
&lt; =""&gt;<!
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
Not so sure what you mean... I looked in the rear, but Im not sure what "panel" you mean. Is it the one where the jack is located? Im not completely following. Would you please elaborate some more? Do you mean left as in the driver side, or left as in if you''re looking at the car head on, which would be the passenger side.
Thank you for your response..
Old Sep 13, 2008 | 08:53 AM
Bdizzle's Avatar
whats the year make model of that
Old Sep 13, 2008 | 02:26 PM
Tony916's Avatar
Its an 2002 Axiom XS
Old Sep 14, 2008 | 10:08 AM
Bdizzle's Avatar
You can get a a factory plug in kit at Napa for 20 bucks all you will need to do is pull your tail lights out plug this in and go and the part # is a 755-1539
Old Sep 15, 2008 | 10:01 AM
  #8
Tony916's Avatar
Did all the searching I could possibly could. All I found was this: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId= 470&amp;LineCode=BK&amp;PartNumber=7551481&amp;Des cription=T railer+Wire+Harness+Adapter+-+Tow+Vehicle
and its definitely not 20 bucks. I even did a search using part numbers. Could you possibly find it for me and send me a link?
I pulled the taillights and I dont see any plug that is not being used. Do i have to unplug something and replace it with this ''''factory kit'''' ?
I''''ve never had to wire any kind of towing harness, so please forgive me if I sound like an idiot. The more elaborate you could be, there more it would help me.
Thanks a lot in advance...
Edited by: Tony916
doccallahan
Apr 2, 2009 10:20 PM
markjw
Oct 9, 2008 12:34 AM
spearbang
Aug 11, 2008 04:59 PM
alanrush2004
May 28, 2008 01:09 AM
Harleygirl
Jun 15, 2005 05:31 PM
