2004 isuzu axiom stalling
Old Jul 29, 2013 | 12:58 AM
fendlay's Avatar
Default 2004 isuzu axiom stalling
Couple days ago my vehicle was hesitating and stalling out while driving it. I drove it to autozone the next morning to test the battery and the alternator. The alternator was fine but the battery said it was bad. Probably a dead cell. I also had a check engine light on. We tested and see what code it threw. Code P1245 - Low Fuel Pressure System. I recently replaced the fuel pump and fuel filter. The car starts but still stalls out. Employee at Autozone said it's the fuel pressure regulator. I'm not to sure if that's the problem. I drove it home this morning and it had lot's of hesitation and stalled out 4 times getting home. Auto store is about 6 miles away from my house. My next try is the fuel pressure test.
Wow. On my vehicle there is no port to do the fuel pressure test. sigh, I did find a hole in a hose connected to some sort of selenoid valve. So I cut the hose down the hole. Wasn't very much. I reconnected the hose and it hasn't stalled again. I test drove it all morning and took it to get 93 put in it. So let's see what happens.
Any help would be appreciated. I been trying to fight and figure this thing out for the past 3 days. Does anyone have an idea/know what could be the problem?
Thanks in advance
Old Aug 2, 2013 | 12:18 AM
Thomas Jacusy's Avatar
You should change the battery as it will must gives you the nice suggestions to have in.
fendlay
Axiom
Aug 13, 2013 01:08 AM
splockit
Aug 10, 2011 10:26 AM
Middawg2
Axiom
Sep 9, 2008 01:07 PM
eubank
Axiom
Sep 9, 2008 08:39 AM
Middawg2
IF Help & Suggestion Center
Sep 7, 2008 08:33 PM
