Weird starting/running issue
Old Jan 23, 2010 | 11:36 PM
rbmcveigh's Avatar
Default Weird starting/running issue
I have a 93 Amigo with the 2.3.L engine. Normally the thing runs great, even for an older model, starts up immediately, but once a month it has a temper! I will try to start it and it will maybe make 1 full revolution and stop and make a thud/click sound, almost like it's seized. If I try to start it again, just a click and the lights go dim. I have learned that if I push it enough to get some momentum and release the clutch in gear, it will turn the engine enough that I can start it, but it runs like hell, smokes, and stinks of gas. Usually after this method though, it takes a while to get it started even though the engine is turning over.
Any ideas before I start randomly throwing parts it at?
Old Jan 26, 2010 | 05:49 PM
jamsesh's Avatar
Almost sounds like the starter but that doesn't explain the smoke and gas smell once you get it going...
Are all your oil levels ok? It's not seizing due to lack of oil right?
Old Jan 28, 2010 | 09:03 AM
rbmcveigh's Avatar
No, the oil level is fine. I was going off the idea of maybe a hydrolock, but the levels in the oil and radiator never change. But Hydrolock should be more consistent that just once a month.
DevinDahlgren
Mar 2, 2012 11:03 PM
2000suv
Sep 10, 2008 07:44 PM
CaptainNoah
Mar 2, 2008 11:31 AM
winchester0101
May 16, 2007 07:37 PM
4L4N
Apr 1, 2007 06:07 PM
