horn stuck..??
so go to my car and notice the horn is beeping.. i was like wtf.. then i hit the horn hard a few times and it stopped.. can it be related to the cold.. horn going bad.. or what? thougths??
if the contact spring in the column has gone soft, it can make random contact due to the temp in the car. As the plastic housing and parts expand or contract it can be just enought to make contact. If it is cold out and the horn sounds use a hair dryer see if it still happens when it warms up.
I believe that part is called a clock spring - always be careful working around air bags
