99 2.2L with P0300
Hey All
Got a stubborn p0300 code that will not go away. I had to replace the engine because of a broken plug and gouged cyl. Installed a new clutch and flywheel, plugs, wires, coil, and injectors with the new engine. Code came right back after engine was installed. No miss is felt and I checked the fuel pressure which is within range. The flashing MIL seems to set after about 4-6 minutes after a restart, even if I turn the engine off on the highway and restart at speed. Part of the exhaust is aftermarket. (Crappy job with the install.) Everything is oem within the engine bay. No addons. Mileage is 112K miles. New engine has 1000 miles.No other codes.
