2.2L Starter Removal
Old May 28, 2015 | 11:24 PM
Spoons896's Avatar
Default 2.2L Starter Removal
Hello all! I am trying to help a friend replace the starter on his 98 Amigo with the 2.2L, we fought with it for a few hours today but it got to dark and we where tired of messing with it. I have been looking around for the best way to replace it and am unable to find anything, anything i have found says you need to remove the y-pipe for the exhaust but the starter on this one is on the passenger side. I have a friend that works at GM and he looked it up on their data base and it says the same thing. We have the bottom bolt that comes in from the front removed but we are unable to get to the top bolt and still have enough room to move the ratchet. the other issue we are having is getting to the power connectors for the starter, the only access we can see to the starter is a 3ish inch wide spot between the Radius Arm and the front Drive shaft. Do we need to remove the intake to replace the starter? I hope some one has some insight and there is some thing simple I am over looking. Thanks in advanced.
Old Nov 22, 2015 | 05:42 PM
psycho6836's Avatar
i've got the 99 3.2L 4x4 i had to remove the driver side engine mount bolt, jack up the engine and pull it out threw driver side wheel well, also had to disconnect the steering linkage.. let me see what alldata says.
Old Nov 22, 2015 | 05:46 PM
psycho6836's Avatar
according to all data, it says to remove battery cable, remove harness connectors from starter, remove the starte bolts and should pull out..hope it helps! let me know if you need the pics. (drawn not of actuall vehicle)
Amsiraha
Jun 25, 2021 06:54 AM
temeculaguy
Dec 29, 2008 11:50 AM
walleye_h
Dec 14, 2008 11:58 PM
Jefffryfry
Oct 4, 2008 11:31 PM
