Lifter noise??? (probably repeat)
Old 08-06-2008, 03:19 PM
94trooper's Avatar
I am sure that this has been asked here a million times but oh well, once more won''t hurt.
I have a 94 trooper with 130k miles. In the mornings I get a noise from the lifters for about 1 1/2 mins then it goes away. What''s the deal with this? Is it something to be concerned about?
Thanks!
Old 08-21-2008, 10:50 PM
kurtdaniel's Avatar
Originally Posted by 94trooper
I am sure that this has been asked here a million times but oh well, once more won''''t hurt.
I have a 94 trooper with 130k miles. In the mornings I get a noise from the lifters for about 1 1/2 mins then it goes away. What''''s the deal with this? Is it something to be concerned about?
Thanks!
Try dropping by to a local Autopartswarehouse</font>, and look for a product called seafoam buy it and follww directions on the bottle.
Old 12-18-2011, 03:37 PM
Rodeo00's Avatar
You may need to adjust your valve lash on your rocker arms under the valve covers. You can find out how to do it in an auto repair manual. It will give you the steps and what clearances that the valve lash should be. Hope this helps.
melcher
01-20-2023 09:40 AM
deoodles
07-19-2006 06:05 PM
K@M@K@Zee
06-27-2006 10:42 PM
DEEBEE
03-28-2006 11:03 AM
blurex7
05-27-2005 02:06 PM
Quick Reply: Lifter noise??? (probably repeat)
