help! oil probs w/ 00 trooper 3.0L diesel
Old 07-26-2006, 04:41 AM
RDL888's Avatar
my car has this weird oil problem,everytime i start the car the oil light is on and the kpa is at 0,so what i would do is turn it off and start it again (for about 4-5 tries) then the kpa would shoot up and so is the oil light.this only happens everytime i park the car overnight (8-24hrs).once the pressure is ok,the car is ok (even when turned off for a couple hours),then i would have the same problem the next morning. every oil change the oil pressure is good (just one start and the kpa would shoot up) but only for a couple days.
if the oil pump is not working properly,why would the car be fine for the day as long as i do the start-off procedure?
any1 with the same problem?
Old 08-28-2006, 05:50 AM
rmb60's Avatar
In Australia they call the Trooper----Jackaroo...I had the same EXACT same problem with mine and eventually they found the Oil Pressure sender was faulty and since replacing it the problem has not re-occured...That was approx a year ago.
Gdafpaaa
06-16-2011 11:26 PM
undergroundmini
Pickup
03-12-2008 09:23 AM
skyline2m
10-19-2007 04:44 AM
feroda
10-10-2007 03:50 PM
trooper90
12-01-2006 04:49 PM
Quick Reply: help! oil probs w/ 00 trooper 3.0L diesel
