transmission check/fill plug
Old 03-31-2012, 08:52 PM
elsleepster's Avatar
Question transmission check/fill plug
I was checking my fluids on the differential, transfer case and transmission. I have a 98 Rodeo with a automatic transmission with no dip stick and had a hard time finding the filler check plug. I stumbled across a diagram showing the check/filler plug about 6 inches from the drain plug.
transmission check/fill plug-91097106.gif
I talked with a mechanic today and the filler check plug is the higher of the two on the pan. Said it needs to be running in neutral on a flat surface.
Never knew how convenient having a dip stick was til now!
tonytwotime
07-08-2013 04:34 PM
bali kute
06-28-2011 02:41 AM
aznxstazy
02-06-2010 12:51 PM
pankary
03-11-2008 08:59 AM
pedro62
01-31-2008 06:21 PM
Quick Reply: transmission check/fill plug
