99 rodeo 2.2, anyone know torque specs?
Old Mar 11, 2006 | 10:08 PM
ferguson_seth's Avatar
what to torque the main/rod bolts to? how about the baffle? oil pan?
i just put new bearings in, and i need the torque specs before i put it all back together and tighten them up!
thanks in advance!
Old Mar 18, 2006 | 07:59 PM
I may be too late but here are specs from haynes. They are to be tightened in stages. Dont see anything about the 'baffle'.
Balance Unit Retaining Bolts
step 1 168 in-lbs
step 2 45 deg rotation
Main Bearing Cap Bolts
step 1 36 ft-lbs
step 3 15 deg rotation
Connecting Rod Cap Bolts
step 1 25 ft-lbs
Oil Pan Bolts
step 1 70 in-lbs
step 2 30 deg rotation
Oil Pan Support Bolts
168 in-lbs
Old Mar 18, 2008 | 02:08 AM
gnr_70's Avatar
Hi Gizmo, can you add the torque spec for the throttle body of a 98 Trooper? I'm going to clean out the carbon junk buildup in the front pipe that may be causing my check engine light to be on. Thanks< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old Mar 18, 2008 | 06:01 PM
I dont have specific info on troopers but for rodeo 3.2 it says 17 ft. lbs. I would imagine it would be the same for the trooper.
crisjacof
Jan 23, 2013 12:07 AM
tamaforlife
Jun 3, 2012 01:21 PM
MrJohnWayne
Apr 7, 2010 12:58 PM
Ohmega_Unit
Jan 18, 2008 09:33 PM
dane
Dec 4, 2007 06:52 PM
