98 Isuzu Rodeo 3.2L S auto bad noise
Old 12-01-2007, 04:39 PM
daisysride's Avatar
frontend makes bad noises. rack&pinion has been replaced with an aligment. didn't replace tie-rods. they look OK. the bearings in and out have been replaced. and doubled checked. my lugs are bad, but lug nuts tighten wheels down tight. the anti-sway links also have not been replaced. its a cluncking noise. 2wd
anyone thank you
&lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>&lt; =text/&gt; _uacct = "UA-939292-44"; urchinTracker(); </>
</>Edited by: daisysride
Old 12-02-2007, 01:45 AM
Could be lots of things. Mine clunks too, havent tracked it down yet. Check to see if the sway bar is hitting the shocks, thats a common problem. Could be ball joints, control arm bushings, body mounts. Look at the front body mounts, should be a 2mm gap between the mount and the UPPER rubber peice. If not then #2 and #3 body mounts need to be shimmed. I have a TSB about that if you need it. Getting ready to order shims for mine.< src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44";
Old 12-02-2007, 07:20 PM
daisysride's Avatar
Thanks I need to collect all my reciepts so when something is wrong I can replace it. I will check all that. The sway bar is out of the way its probably a ball joint.
thanks again
Old 12-20-2007, 05:22 PM
daisysride's Avatar
not sway bar, it has to be the ball joints. they will not break though. I got them off ebay for $40 instead of almost $300 at auto part store.
daisysride
Old 12-20-2007, 05:23 PM
daisysride's Avatar
How do you have a 3.2L 5-speed?
Old 12-20-2007, 08:38 PM
Lots of 3.2l 5speeds around. I think they sold about the same number of 5 speeds as autos.Thats one of the reasons I bought this one, I wont buy an automatic, dont like them.
Old 12-21-2007, 04:27 PM
daisysride's Avatar
My automatic is great b/c I tow my boat, but I have alot maybe just 98's 3.2L are only auto and no sticks. Cool man keep it!!
Later
  #8
Old 12-22-2007, 12:57 AM
I've seen some '98 5 speeds. Maybe they arent very common in your area.
Hopefully you have a tranny cooler on yours and keep up with fluid changes with pulling the boat.
  #9
Old 12-26-2007, 05:07 PM
daisysride's Avatar
no long story short engine has been rebuilt 3times in 2years. I have only put 9K on the entire truck.
Anthony08618
04-12-2009 09:35 PM
yhperformance
08-29-2008 03:17 PM
daisysride
12-01-2007 04:34 PM
vaman4215
08-14-2007 06:48 PM
robertp
08-04-2005 12:46 AM
Quick Reply: 98 Isuzu Rodeo 3.2L S auto bad noise
