engine change
Old 03-24-2008, 07:58 PM
2002troop's Avatar
&lt; src="http://www.google-analytics.com/urchin.js" =text/&gt; </>Wondering if anyone has ever changed a motor in a 2002 isuzu trooper and if they have do you know if you have to take the front pumpkin assembly out to make it easier to replace the motor? any help would be greatly appreciated.. thanks &lt; =text/&gt; _uacct = "UA-939292-44"; urchinTracker(); motor is a 3.5 if that might help.. sorry..</>
</>Edited by: 2002troop
Old 03-27-2008, 08:23 PM
ISUZUGURU's Avatar
Super Moderator
no you do not have to move the front diff.i would just put a long bar or a long extension across the torsion bars right underneath the trans bell housing,this keep the trans from droping to the ground,keeps it up right.then just lift the engine up an pull forward,an it will come right out.do the opposite when installing,the lower oil pan WILL lift up an over the differential.some pepole will lower the diff ,but it really not neccesary.there is a small 4 pin connector at the very top front of the trans bell housing,its part of the engine harness ,disconnect it .its wraped in foam tape.as you disconnect the o2 sensors an trans bolts look closley up there an you will see it.
leejm12
07-07-2010 10:02 AM
borneojunglepilot
12-31-2009 12:44 PM
absosecur
VehiCROSS
12-16-2009 09:25 PM
ephebus
09-08-2006 03:18 PM
robdog
03-25-2006 12:31 AM
Quick Reply: engine change
