Wheels and Tires All wheel and Tire discussion
DIY: Refinishing Steel Rims (Video)
Old Jul 29, 2011 | 04:37 PM
ProStreetDriver's Avatar
Default DIY: Refinishing Steel Rims (Video)
How to refinish steelies on a budget. This involves repainting your rims using spray bomb/rattle cans.
What you'll need:
flat screw driver, paint marker, wire brush, 200-400 grit sandpaper, brake cleaner, clean cloth, painter's tape, paper, dull knife/flat edge, primer, paint (color choice)
Procedure:
-remove rims from vehicle
-mark where wheel weight are located with paint marker
-remove loose rust and paint using wire brush
-sand down rim using 200-400 grit sand paper
-clean rim using brake cleaner and cloth, then let dry off in sun
-tape off tire and valve stem
-primer rim and allow for approximately 10min dry time
-apply selected paint choice (3 coats)
-let paint dry and remove tape
-reinstall wheel weight
-reinstall rim on vehicle
ProStreetDriver
Detailing
Sep 17, 2020 07:55 AM
ProStreetDriver
Detailing
Apr 7, 2012 04:24 PM
ProStreetDriver
Exterior
Nov 19, 2011 06:49 AM
ProStreetDriver
Wheels and Tires
Aug 5, 2011 09:10 AM
ProStreetDriver
Wheels and Tires
Jul 4, 2011 05:07 PM
