Wheels and Tires All wheel and Tire discussion
DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
Old Aug 5, 2011 | 09:10 AM
ProStreetDriver's Avatar
Default DIY: Installing A Plug To Repair A Tire Leak (Video Tutorial)
How to install a plug to repair a puncture/hole in the tread face of a tire. The sidewall cannot be repair as it is unsafe and illegal.
Procedure:
-remove tire from vehicle
-find air leak using soapy water and watch for bubbling
-remove object in tire using a screw driver, pliers, etc
-using the reamer from the tire repair kit, stick in the in the hole so it goes through to the other side, twist reamer to clean hole
-load plug into needle, center plug in needle
-stick plug 2/3 length tire with 1/3 left exposed to the outside
-pull needle straight out quickly without twisting
-cut off access plug using side-cutters, razor, etc
-pump up tire and reinspect for leak
-when all is done, reinstall tire on vehicle
ProStreetDriver
Detailing
Sep 17, 2020 07:55 AM
ProStreetDriver
Exterior
Sep 6, 2018 02:13 AM
ProStreetDriver
Detailing
Apr 7, 2012 04:24 PM
ProStreetDriver
Exterior
Nov 19, 2011 06:49 AM
ProStreetDriver
Wheels and Tires
Jul 4, 2011 05:07 PM
