What is the proper oil pressure for a 94 trooper
Old Mar 8, 2016 | 11:43 PM
HeadyGlassKing's Avatar
Default What is the proper oil pressure for a 94 trooper
3.2 L SOHC with 100k on it. Mine cold starts at 30psi and runs at normal temp around 15psi. Do they normally run that low?
Old Apr 16, 2016 | 03:44 PM
jcolmar's Avatar
Cold Idle: 40psi
Warm Idle: 15psi
yes the warm idle pressure is quite low.
cruising around at 2500rpm pressure is right around 30psi
mine is a SOHC 94' with 305k miles
mackstewart
Nov 12, 2012 05:10 AM
ValerieMc1
Sep 30, 2010 08:22 PM
gratefulartist
Sep 23, 2009 11:09 AM
gratefulartist
Sep 23, 2009 09:42 AM
beachfairymd
Feb 9, 2009 07:37 AM
