kegriffinjr |
08-11-2009 08:32 PM |
Trooper won't start
I have a 93 3.2 SOHC and replaced the starter. Before replacing exhaust pipe I hooked up the battery to check starter. I did not crank it long enough to start but got a small backfire. I buttoned everything up and now truck will start after sitting awhile but will only run for a second. I replaced fuel filter,checked fuel pump,fuses and relay. I also sprayed O2 sensor connection with electrical cleaner because it was coated with oil and grime. Any help would be GREAT. THANKS
