Trooper engine trouble
Old Nov 5, 2007 | 11:32 PM
Bartamus's Avatar
My 92 3.2 trooper starts and runs fine for about ten to twenty min and then looses power and almost dies pressing on the gas makes it worse. Turning off the ignition seems to reset somthing and I am able to drive for another few miles beforeit happens again. I have changed the IAC, the plugs, air and all the other filters. It runs fine at an idle. HELP!!![img]smileys/smiley6.gif[/img]
Old Nov 22, 2007 | 01:46 PM
seantg's Avatar
is ur check engine lite on ?
i would check the EGR valve
or
some sort of vacuum leak
(soapy water or Carb cleaner )with engine running listen for changes while u spray
Old Nov 23, 2007 | 01:58 PM
tripjax's Avatar
I agree EGR valve or throttle position sensor.
mschott
Mar 23, 2012 10:27 AM
mikeyr
Jul 29, 2009 06:53 PM
nickhuts
Apr 21, 2008 12:19 PM
jcbearle
Aug 25, 2007 08:56 AM
skidmarc
Apr 12, 2007 06:57 PM
