Torque spec for ’99 Trooper hub & brakes
Old Nov 27, 2006 | 04:33 PM
chanceintx's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
I'm doing a front brake job on my '99 Trooper and I need to get the rotors turned, so I need to remove the hub and rotor. The problem is, that I can't find a repair manual for it, so I don't have any of the torque specs for re-assembly. If you know the specs or a source for a repair manual I would really appreciate it. I haven't finished the disassembly yet, but I think these are the only specs I'll need.
I'm looking for the torque specs for the following:
- hex bolts that connect the axle and hub
- spindle nut
- three screws that hold the spindle nut retainer
- bolts for the brake caliper mounting bracket
Thanks in advance.
tathanhthientu
Feb 5, 2011 07:30 PM
NCHornet
Jul 29, 2010 12:06 PM
the wolverine
Feb 8, 2009 03:48 PM
Middawg2
Sep 7, 2008 08:38 PM
JTOB
Aug 11, 2007 06:54 AM
