-   -   Tips on replacing starter 99 trooper? (https://isuzuforums.com/forum/trooper-18/tips-replacing-starter-99-trooper-36113/)
shane.bowser Apr 26, 2010 01:53 PM
I am replacing the starter on my 99 Trooper and am having problems getting to the bolts I need to take off. Any suggestions would be great.
Cali_drvr78 May 12, 2010 03:32 PM
Hello Shane,
http://wiki.answers.com/Q/How_do_you..._isuzu_trooper
not sure if this will help but I am going to try it as well since I just purchased a trooper 99 and the starter needs to be replaced. Good luck, do you know where I can buy a manual for this car? I am going to be doing the oil change and tranny oil on it. I will also be doing the tune up and want a point of reference. Thanks
fourwd1 May 17, 2010 11:51 AM
Be sure to disconnect the battery cable before starting !
Do not waste your money on the Factory Service Manual CD, I did and it's not very good.
If you have the auto trans, changing the ATF is a pain, there is no dipstick.
rmelichar Aug 9, 2012 10:12 PM
Thanks for this I've been browsing through this forum as I had a problem starting my car occasionally. I thought its the solenoid that is built in to the starter motor. I'll just try this. I hope it's easy. Thanks. http://www.supernissans.net/forums/i...lies/smily.gif
________________________________________________
"Driving a brand new car feels like driving around in an open billfold with the dollars flapping by your ears as they fly out the window. ~Grey Livingston"
http://www.partstrain.com/ShopByDepartment/Starter
randomorbit3 Aug 11, 2012 03:09 PM
The solenoid is part of the starter and is sold with the starter. Which engine do you have. If it is the 3.2L you have to drop the exhaust from the manifolds and the cat. It is a y-pipe. also unplug the O2's on each side the once that is out of the way the started is fairly assessable.
Hope this helps.
randomorbit3 Aug 11, 2012 07:07 PM
Sorry that was supposed to say starter is fairly accessible :)
KeithHoward Aug 28, 2012 01:33 AM
randomorbit3 Aug 28, 2012 04:15 PM
Isn't it so much fun pumping it in especially if you do not have a pumping set-up?? All that to save some money on a dipstick and try to force you to take it to the dealer or places like that to change the fluid!!!!!!
