-   -   Timing Belt Light Reset?? (https://isuzuforums.com/forum/trooper-18/timing-belt-light-reset-1095/)
sony_ice Jun 18, 2007 09:25 AM
Hi all,
I have a 1992 Isuzu Bighorn 3.1 TD i believe these are the same as Troopers with probably only slight difference if any.
Anyways now to my problem, the Bighorn has recently just hit 80500 miles on the clock but the T-Belt light came on at 80000. I have now had the T-Belt changed but the light is still on, on the dashboard. The garage said to reset it they would have to remove the dash to get to the bulb & take the bulb out, but i wasn't sure if this was the right way about it.
Is there no easy way to reset the T-Belt light, like to disconnect both the battery's or is there not a reset button somewhere?
Isremoving the dash & bulb the only way to reset the light?
Please help someone if you know.
Cheers all,
Ian.
djkanon Oct 15, 2017 12:20 PM
reset timing belt light
how to reset timing belt light isusu truck 4jg2 model 1995 no cable meter?
