Stuck transfer case and rubbing clutch
Hi I'm having a problem with my 1988 Isuzu trooper. I took it off roading for the first time and got it stuck in the mud.
after I drove it home I had to replace altanator, starter and rear main seal because the water and mud damaged it, I was in need of changing the clutch so I said what the hell midis well so, I pulled the tranny and changed the clutch out and put it back together. I started it up and it started just fine but had a weird noise coming from the tranny. But every time I push in the clutch it stops. When I let the clutch out it makes that noise like if the clutch is rubbing??? My gears have been grinding ever since i dont know why?? I blead the clutch and everything is good so i dont know why its been doing that. And after I noticed the transfer case is stuck on 4h and won't go back to 2h?? I checked if the front automatic locks were ingaged but there not since Ive been driving it all over the place even different country's I tried forcing it back to place but I don't want to brake anything?? Can somebody please help me???
