-   -   P0420 and P0430 codes (https://isuzuforums.com/forum/trooper-18/p0420-p0430-codes-39523/)
ar3em11 Oct 15, 2012 05:30 PM
I have a 2000 trooper. Driving home today CEL comes on. I get home and run the codes and its P0420 and P0430 at the same time. Im aware that the codes are saying bank 1 and bank 2 catalyst not functioning properly, but I find it extremely hard to believe that both cats went bad at the same time. Anyone else experienced an issue like this or know what else could cause these codes.
Truck does run fine, no hesitations, starts fine, acceleration is fine. Im at a loss at this point.
guildasasd44 Oct 16, 2012 01:37 AM
these heroes were not meant for guild wars2
In accordance with that said just before, the ball player will probably with amount 25 approximately spend 30 a long time to perform common problems, however the truth is that this participant however is actually at amount 40 roughly to perform widespread issues, nevertheless the genuine the fastest player just are cheaper compared to about 8 hrs.gw2 gold Acquire Diablo Three Platinum Correctly To take pleasure from The particular Satisfaction Inside Diablo 3. The following is any blizzard azure put up written content: Person: and also acquire eight several hours after the on the web Thirty minutes, and lots of people to have slain problem issues a higher level the 3rd act.
