Is only option to get another engine? 95
Old Dec 8, 2023 | 01:12 PM
Travistrooper's Avatar
Default Is only option to get another engine? 95
My 95 Trooper busted the intake hose and I didn't know it then the cylinders would begin to bogg out after running it in accelerate stop then accelerate traffic . It now does it more often any advice? It seems to me its the cylinders shutting down when running through heavy neighborhood traffic and lots of stop signs . Today it did it for driving 6 miles not through traffic but after I left the cafe it started doing it. If I stop at the store mid trip then turn back on its like it got hot while sitting off then starts running real rough and no power hardly. Has anyone had good outcome getting a engine from a salvage yard then fixing it up?
Old Dec 17, 2023 | 11:24 AM
Hooligan's Avatar
Have you run a compression check? If they're all about equal and over 120ish then the problem likely is something else. If you buy a junkyard motor you should also check the compression before buying. When was the last time the timing belt was replaced?
Old Dec 17, 2023 | 03:05 PM
The engine I found 1st from a nation wide group says he won't be able to do a compression test until I purchase because they have to pull the engine out to do the compression ( he sounds honest at least). If would be under warranty. He says he would need to confirm and send pics as he did on his own for the last part I bought from him.
But I found another engine for far more less price that has had a compression test. I just need to follow up with him about the numbers. This is from a car dealer that my Mother knows and bought her vehicle from, he has the sources so I'll prism purchase through his guy.
I also have a small bronco 2 that I have a brand new engine now for, the mechanics are finally starting the install so I'm going to be focused on it for now and will have to pick up on the isuzu a little later.
thanks fir the help much needed, I had the trans built and can't give up on this Truck.
Thanks
Leeland Waller
Feb 25, 2019 07:49 AM
gorewhore
Mar 31, 2011 01:19 PM
mikeyr
Jul 29, 2009 06:53 PM
Dixietrooper
Dec 20, 2008 11:05 PM
shady12
Jul 25, 2007 07:47 PM
