-   -   O2 sensors (https://isuzuforums.com/forum/trooper-18/o2-sensors-2512/)
gnr_70 Nov 10, 2008 09:06 PM
1998 Isuzu Trooper, 3.5L Automatic.
How many sensors are there in this year model?
I have checked underneath the truck and saw one before the catalytic converter, (3 wires), on the drivers side. Saw another sensor on the passenger side (4 wires)...
However, when I check partsamerica.com for this it shows :
<a href="http://" target="_blank">
http://www.partsamerica.com/ProductL...artType=291&am p;PTSet=</a>A
it says 2 each required for the upstream and 2 each for the downstream...
Where are the two other sensors located?
[img]smileys/smiley6.gif[/img]
bsmart10 Nov 12, 2008 12:18 AM
There are 4 O2 sensors, 2 are in front of the catalytic converters and the other 2 are just behind the catalytic converters. They are about 12 inches behind them, hard to miss actually. Take another look.
gnr_70 Nov 12, 2008 10:56 PM
I did and saw the other two....the passenger side''s PreCAT O2 sensor was way up and had to use a flashlight to see it. then the After Cat o2 sensor on the drivers side was hiding above a metal protector tab. I noticed it when I was on the passenger side angle.
Thanks....
