O2 sensors
Old Nov 10, 2008 | 09:06 PM
gnr_70's Avatar
1998 Isuzu Trooper, 3.5L Automatic.
How many sensors are there in this year model?
I have checked underneath the truck and saw one before the catalytic converter, (3 wires), on the drivers side. Saw another sensor on the passenger side (4 wires)...
However, when I check partsamerica.com for this it shows :
<a href="http://" target="_blank">
http://www.partsamerica.com/ProductL...artType=291&am p;PTSet=</a>A
it says 2 each required for the upstream and 2 each for the downstream...
Where are the two other sensors located?
[img]smileys/smiley6.gif[/img]
Old Nov 12, 2008 | 12:18 AM
bsmart10's Avatar
There are 4 O2 sensors, 2 are in front of the catalytic converters and the other 2 are just behind the catalytic converters. They are about 12 inches behind them, hard to miss actually. Take another look.
Old Nov 12, 2008 | 10:56 PM
gnr_70's Avatar
I did and saw the other two....the passenger side''s PreCAT O2 sensor was way up and had to use a flashlight to see it. then the After Cat o2 sensor on the drivers side was hiding above a metal protector tab. I noticed it when I was on the passenger side angle.
Thanks....
WrenchTurnerDave
Jan 23, 2013 02:01 PM
gnr_70
Nov 9, 2008 10:09 PM
Ticomia
Jun 16, 2007 02:33 AM
airdale
Dec 28, 2005 03:40 PM
