-   -   needle bearing? (https://isuzuforums.com/forum/trooper-18/needle-bearing-39240/)
rayfaith23 Jun 28, 2012 12:06 PM
needle bearing?
Hello,I have a 99 trooper a am having a problem with the left front wheel being well loose maybe. What it does is you can rock the tire back and forth a very little,garage will not inspect it says it needs fixed. I have checked the wheel bearing and that seems good if anything i have it too tight now so my thought is that its the needle bearing in the hub. Can you fellows comment,agree or disagree and what you think. If you think i am right would someone have a part number and where to get it? thank you,Ray
