Well my 97 Tooper's rearend that is. I just got the Trooper and looks like the rear has a leak. Anyone ever replace the seal on the center chunk? Is this comon with the Trooper? Also has anyone found a repair manual for one of these? Thanks! |
I picked up a chiltons manual at advance auto parts...
I would think about any store which sells books should be able to get you one. looks like amazon has one... http://www.amazon.com/Isuzu-Pick-Ups...981-96-Chilton s/dp/0801986869/ref=pd_bbs_1/102-8157597-1044920?ie=UTF8& ;s=books&qid=1186880685&sr=1-1 |
I do think this is semi-common on Troopers. One Mechanic told me
that this is the one of the few downfalls of this vehicle. I have an 88 trooper that has that problem. I removed the drive shaft, and rear axles. Took the rear differential apart, and made a gasket out of blue RTV. This worked great for a while, but eventually transfered the pressure and blew out the seal on the pinion. I still have a small drip coming from the point where the shaft enters the diff, but its slow and i just refill it every few months. I put Lucas oil in there as well and it helps keep the seals swelled and drips much slower. I just live with it now, and dont feel its even worth my time to really really fix it. Hope this helps. |
| All times are GMT -5. The time now is 07:09 AM. |
