-   -   my heat,a/c doesnt blow hard enough! (https://isuzuforums.com/forum/trooper-18/my-heat-c-doesnt-blow-hard-enough-39268/)
skorch1ss Jul 17, 2012 05:52 PM
hey guys, i have a 96 trooper, i love the thing it gets me every where i need to go, but it seriously has me looking to get something else, simply because i cant get the cabin fan to hardly blow at all!! My heat and a/c works completely fine but the problem is i cant feel it! Basically is HOT in the summer and its COLD and winter. I cant stand it im so frustrated. Im wondering if anyone else is having this same problem??? or if there is something i can do to improve on it! any help would be much appreciated, i really dont want to get rid of this thing! thanks
randomorbit3 Aug 11, 2012 02:30 PM
Have you checked how things feel when on recirculating air?? If things are OK that way then you need to clean out the air inlet or the duct that is supposed to open when you turn on for heat or a/c. Try putting it on vent mode and drive it and see if air comes out the duct. The faster you go the more air you should get. If no or very little air check to make sure all of the vacuum diaphragms are working.
Hope this helps.
