Manual Transmission overheating
Old 07-16-2007, 01:54 PM
DaTrooperQ's Avatar
I have a 96 trooper with a manual transmission. Lately when I
drive it the transmission get hot and it's so hot I can smell it sever
feet away. The trooper seem to run fine, but I know it's a ticking time
bomb. Any suggestions on what to check. It has fluid.
Old 07-20-2007, 11:28 AM
ISUZUGURU's Avatar
Super Moderator
make sure the fluid is not draining back into the transfer case,if you have been addding fluid its going somewhere,check the trasfercase an see if its overfull,if so the sealas between the 2 are going bad,an will cause the input gear to starve for fluid an cause damage.the trans is in a slight tilt down so if it get too low all of the remainoing fluid in the rear causing the ft gears to be oil starved.i have a tool box full of input shafts now only good for clutch alignment tools cause of this,concern.
spearbang
08-11-2008 04:59 PM
appliancethug
06-25-2008 08:59 PM
DarkSideofWill
I-Mark
01-25-2008 12:56 PM
Louster
07-25-2005 06:47 PM
mrdicerolla
07-01-2005 11:23 AM
Quick Reply: Manual Transmission overheating
