keep blowing fuse for inside dash lights
I have a 98 trooper mine did this to when I got it found out the radio was wired wrong and the plate light had an LED causing a short
Fuses will only blow because of either an overload, or a short to ground (hot wire grounding out). Check all of your interior lights starting with the easiest to get to and work your way around the circuit, you'll find the problem. You may also have installed something that's drawing more amperage than the circuit was intended, so check anything you may have installed aftermarket. Another method would be to disconnect things until the fuse stops blowing, then you'll know exactly where the problem should be. What ever you do DON'T JUST INSTALL A HIGHER RATED FUSE, that will eventually cause more damage than already exists.
Did you find the cause of your electrical problem on your ISUZU?
Did you find the cause to your electrical problem on your Isuzu?
#8
