How to get motor to turn 1987 trooper
Old May 31, 2010 | 09:58 PM
rlowhorn's Avatar
Default How to get motor to turn 1987 trooper
I purchased this trooper new in 1987. We put 180000 on it. Had a few problems with it and set it up. It was in the weather and just set for seven years. Body is in great shape. I now want to get it running and rebuild. I pulled it into the dry. Cleaned it up. Checked fluids. Put gas into it. Put a battery to it. Turned to key. Nothing. Not really surprised, but would like to now start the journey. How do I get it to turn, or should I without first doing something else. Anyone have a check-list of getting started on a rebuild? Never rebuilt a car. Have done a lot with tractors and will do this. Any help?
Old Jun 27, 2010 | 02:10 AM
Full Pull's Avatar
SOUNDS LIKE A BAD GROUND... check and clean ALL GROUND WIRES if all grounds are good then it could be ummmmmmm??? just about anything
johnc
Jul 12, 2011 10:49 AM
87trooper2
Aug 12, 2010 08:32 AM
mikeyr
Jul 29, 2009 06:53 PM
scr8pin_pup
Sep 12, 2007 06:49 PM
MrIsuzu0481
Jul 13, 2005 11:14 AM
