help...wont run past 50mph
Old 02-13-2011 | 11:46 PM
saicam's Avatar
Default help...wont run past 50mph
I have a 1994 trooper...the problem is that when I drive my car past 40mph...the car will vibrate like crazy...what seems to be the cause...the mechanic doesnt' know what to do....thanks.
Old 02-18-2011 | 04:38 PM
jeffs_62's Avatar
Have you looked at anything yet?
Virtually any rotating part can give you a vibration at speed. So I'm going to suggest you start there.
Old 02-19-2011 | 07:41 PM
saicam's Avatar
thanks. I'll have the mechanic look at it on monday.
Old 02-19-2011 | 09:35 PM
jbriones23's Avatar
Vibration can come from a variety of causes: loose ball joints, incorrect wheel alignment, and one thing I personally experienced before.. a protrusion in one of the tires. One tire had a bump probably due to over-inflation.
Old 02-21-2011 | 10:42 PM
jeffs_62's Avatar
All the things mentioned by J^^ are true but would probably be visible long before forty miles an hour. It's probably a U-Joint.
Old 02-22-2011 | 02:05 PM
saicam's Avatar
thanks. do you think it could be the driveshaft also?
Old 02-22-2011 | 07:01 PM
jeffs_62's Avatar
Okay,
If it turns or "rotates" it could be "the problem".
So, yes it could be the drive shaft, which, incidentily, is where the U-Joints are located.
If it has the Double Cardon joint (two piece rear driveline) then you will have a total of six U-Joints. The ones in the rear are the most likely culprits.
Although, I said that any part that rotates, could be causing your vibration, it is usually a bad U-Joint.
I don't know where you live but if you are near a Les Schwab, they will check them for free. Most tire shops will. A driveline shop will too.
  #8
Old 03-03-2011 | 05:46 PM
saicam's Avatar
Thank you so much. The problem is the U-joint. Surprisingly, it only cost me $120.00 to fix the problem. Now, I am driving in the freeway again.
  #9
Old 03-04-2011 | 04:20 AM
jeffs_62's Avatar
That sounds a bit steep to me, you got them all changed at that time?
  #10
Old 03-06-2011 | 12:14 AM
saicam's Avatar
Sorry, I forgot to mention that we changed the driveshaft also, in additionto changing the cross joint/U-joint... :-)
