fuel injected models ??
how do you prime fuel injected isuzu troopers, after a fresh engine rebuild??
cycling the key on and off with otu starting it should prime the pump
thanks. it works now, did get a backfire from the throttle body last night. idk if my timing is off to cause it to not start
checked everything but still wont start. IDK what to do
which engine do you have ? do you have fuel to the engine? do you have spark?
