| fobjob |
Oct 20, 2018 05:50 PM |
The short adjuster is probably for a pre-95 trooper. Parts geek sent me a short one, also. The correct one needs to be about 7-8 inches long...Can’t find one anywhere on the planet...So, my right wheel has some Ford F-150 parts...Moog ES3368S sleeve, ES3370T, and ES3369T...Issues: they will need a washer under the nut, as the nut bottoms out a bit prematurely. Also, they are not sealed, so the zerk fittings will require a very short 90 degree adaptor on your grease gun. Point to point distance on a post 94 trooper is about 13.1inches. The Moog parts fit with about two inches of thread engagement each rod.
