-   -   engine dies in park (https://isuzuforums.com/forum/trooper-18/engine-dies-park-650/)
valdum Nov 3, 2006 02:25 PM
My car: Trooper98-Gas
I got the Check engine light on, and I found the error: 0171 and 0174
What is happening: When the shift is in drive the engine runs well. If I
run the car 10-15 min, stop the engine, and then start the car again the
engine dies in 3-4 sec if the shift is in park position; if I move the
shift quickly in drive the engine runs well. - I changed the spark plugs
I changed the air filter and cleaned the area No improvment. Any clue?
Thanks! Val
mliu33 Nov 8, 2006 10:14 PM
i am having the same problem seems that the car drives fine til it comes to a stop and then the engine cutts off but turns back on easily. DId you ever get to the bottom of this?
valdum Nov 9, 2006 10:57 AM
not yet. I have changed the O2 sensors, but that is not solving the problem. another idea is to check for a vaccuum loss , but I did not check that yet.
I hope somebody will come with a good clue.
techNic Jan 15, 2007 05:15 PM
try cleaning the idle speed motor or throttle body out with a rag and some carb spray. this may help an uneasy idle or failure to star
gixxertrix Jan 15, 2007 05:31 PM
mine did that and died when it rained aswell. nobody could figure out why for the longest. Well we finally got it, it was the Oil and the Spark Plugs. I know your not as stupid as me and youve probaly already tried it, but its a start.
valdum Jan 15, 2007 06:37 PM
Somebody found the solution for me : the manifold gasket. After replacement, the engine is Ok. ($400)
