-   -   Engine codes??? '94 Trooper (https://isuzuforums.com/forum/trooper-18/engine-codes-94-trooper-38919/)
ThatDogGuy Mar 23, 2012 08:22 AM
I have a '94 with about 230,000 miles. 3.2L V6, 5-speed manual.
Lately, when I'm on the highway the vehicle will start to run really rough. I loose RPMs, and the engine sounds like it's gasping for fuel or air. After about a minute, it starts running normally again - then the engine light turns on.
I read the code - it's 1,2,1,2,1,2 4,4,4,4,4,4. I have no idea what this means! Does anyone have knowledge or reference material available to tell me where I should be looking?
BTW - I've changed the oil, oil filter, plugs, fuel filter and cleaned the EGR valve in the last two weeks, but the problem persists.
Thanks!
paul
ThatDogGuy Apr 7, 2012 09:26 AM
For the benefit of those looking at this thread in the future, I found the codes are actually 12, 12, 12, 44, 44, 44.
This appears to indicate a bad 02 sensor.
I've got one on order, hopefully that will solve my issue.
