Emergency Brake - what gives?
Old Sep 24, 2010 | 05:45 PM
mangomonster's Avatar
Default Emergency Brake - what gives?
1988 Isuzu Trooper. Disc brakes in the rear.
Parking brake is probably only working about 10%, which means, it's not working!
I get under the car, tighten it up, and it's still not working. If I tighten it too much, it becomes VERY difficult to pull, and even when I do, it still doesn't work!
I watched as my wife pulled the e-brake and I can see the springs move, I can even see the pads moving slightly to apply a BIT of pressure, but I can still easily turn the wheel...
When the brake pedal is pushed, they work fine. Anybody know what's going on?
Old Sep 29, 2010 | 03:02 AM
trooper76's Avatar
did you take the disc off to see the pads and the ajusting piston if the pistion is closed open it a bit at a time untell you find the place you want worked for mine.
Old Sep 29, 2010 | 12:23 PM
hmm.. does that piston adjust both the e-brake AND the brake when I push the pedal? So are you basically saying I need to 'reset' it? I think it adjusts by turning it clockwise/counterclockwise, but I didn't try.
Old Sep 30, 2010 | 08:23 PM
trooper76's Avatar
let me know if that helped you...trooper76
drb930
Private 'Wanted' Classifieds
Jan 1, 2015 09:55 PM
mac
Feb 1, 2012 08:40 AM
rcsen
Feb 5, 2008 01:40 PM
houptee
Jan 3, 2007 10:09 AM
