i have found, through some research in a jeep forum, that a swap from a 2.8 L chevy to a 4.3 L chevy is very doable, especially when using an earlier TBI 4.3 engine.
now, to progress this info further; can anyone tell me if the rest of the existing drive line in an 91 trooper will mate up with the 4.3 L ? what trans was used in the 91 trooper ? if the trans was changed in a 4.3 L engine swap, what would be the effect to the transfer case ? is there a space problem ? mounting issues ? drive shafts match up ? i do know there are a different number of teeth on the 4.3 fly wheel (larger flywheel too), is the number of spline teeth in the center of the flywheel the same ? can the flywheels be swapped from the 2.8 to the 4.3 ? thank you all (in advance) for your thoughts and comments |
