-   -   Distributor seal / 2.6 engine ? (https://isuzuforums.com/forum/trooper-18/distributor-seal-2-6-engine-73756/)
trooperkayaker Feb 1, 2014 12:52 AM
I seem to remember a post that gave a part # for a shaft seal for a 2.6 distributor if the dist. was leaking oil and messing up the module/pickup inside?
Any help would be greatly appreciated thx
Overnite Feb 13, 2014 11:08 AM
This is what Alldata has on this. I could not find a number for the seal itself.
1990 Isuzu Truck Trooper II L4-2559cc 2.6L SOHC (4ZE1) Copyright © 2009, ALLDATA 10.10 Page 1
Vehicle: All Technical Service Bulletins
Engine - Oil Leakage In the Distributor
BULLETIN NUMBER
SB91-04-007
ISSUE DATE
June 13, 1991
GROUP
ELECTRICAL
4ZD1 DISTRIBUTOR HOUSING AVAILABILITY
AFFECTED VEHICLES
All Pickup (TF), P 'UP (KB), Trooper II (KT) and Amigo (TC) models with 4ZD1 engine.
SERVICE INFORMATION
Engine oil leakage in the distributor indicates that the distributor oil seal may require replacement. The distributor housing, which contains the oil
seal, can now be ordered separately from American Isuzu Parts Distribution Network (AIPDN).
PARTS INFORMATION
Part No. Description
8-97045-994-0 Distributor Housing (Pickup
and Amigo)
8-97045-993-0 Distributor Housing (P 'UP &
Trooper)
FLAT RATE MANUAL INFORMATION
Use existing Flat Rate Manual labor operation number 040127.
