CODE 32
if I remember correctly, code 32 is an EGR temp sensor code
with temp at 68f sensor resistance should be 12k
with temp at 109f sensor resistance should be 6k
as temp goes down, resitance goes up
as temp goes up, resistance goes down
Sean
code 32 is an egr code, you have one of 2 problems, either no vaccum to erg valve or something that was common on 3.1l v6 was the egr port in the heads would get clogged, you need to close the valve with your hand and see in the engine tries to die while running if not take the intake off and clean the port, if it does try to stall ck the vaccum to the valve
