-   -   Check Engine Light (https://isuzuforums.com/forum/trooper-18/check-engine-light-35667/)
dfmelton Dec 18, 2009 09:38 AM
Check Engine Light
I have a 2002 Trooper. The check engine light is on. I had the EGR Valve changed and the gas cap. It is still on ??????
oefvetisuzutrooperlover Dec 23, 2009 08:58 PM
scanner
go to your local parts store and use a scanner in order to acquire the codes
some codes are minor such as the cayatltic converter needs replacing. only way to be sure is to get the scanner. i personnaly bought one so i can have it at all times.
