< src="http://www.google-analytics.com/urchin.js" =text/> </> HERE IS A RUNDOWN. CODE FOR EXCESSIVE EGR FLOW, 44 PSI FUEL, HAS SPARK, INJECTORS TRIGGERING, AIR AND ENGINE TEMPS MATCH AND ACCURATE, 28.6 MAP, SCANNER SHOWS CRANKING RPM, WILL KIND OF HALF RUN W.O.T. UP TO 700 RPM AND THEN FART AND STALL OUT LIKE A FLOOD. IT WILL KIND OF HALF RUN W.O.T. ON ONE PLUG INSTALLED AND 5 INJECTORS UN HOOKED. PLUGS ARE ALWAYS WET. SCANNER SHOWS NO AIR FLOW BUT NEW MASS AIR ACTS THE SAME. 15K ON BELT CHANGE. < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
