Recs. on how to adjust idling, idling at about 25rpm...Thanks
how does it run other than the IDLE ?
what started this ? did u do any repairs recently ? any check engine lights ? start with the easy stuff first disconnect the battery cable for like 20 min. check it out first then if that does not get it fixed i would check for something disconnected , Unplugged , or cracked a good thorough inspection answer the questions above try these suggestions & let me know what happened then we will look else where if needed .:Sean:. < src="http://www.google-analytics.com/urchin.js" ="text/"></>< ="text/">_uacct = "UA-939292-44"; urchinTracker(); </> |
< src="http://www.google-analytics.com/urchin.js" =text/> </> there is an idle set screw, its hard to find. its by the trottle body it may be on the intake manifold. itll screw down into it so you really gotta look. but there is one there. < =text/> _uacct = "UA-939292-44"; urchinTracker(); </> |
| All times are GMT -5. The time now is 08:41 AM. |
