98 Trooper Idling Too Fast...
how does it run other than the IDLE ?
what started this ?
did u do any repairs recently ?
any check engine lights ?
start with the easy stuff first
disconnect the battery cable for like 20 min.
check it out first
then if that does not get it fixed
i would check for something disconnected , Unplugged , or cracked
a good thorough inspection
answer the questions above
try these suggestions & let me know what happened
then we will look else where if needed .:Sean:.
what started this ?
check it out first
there is an idle set screw, its hard to find. its by the trottle body it may be on the intake manifold. itll screw down into it so you really gotta look. but there is one there.
