94 trooper timing question
I have a 94 3.2 sohc the timing belt tensioner went bad so I replaced it. When I put the belt back on all of the alignment marks on the belt were lined up with the marks on the sprockets and all of the sprockets were lined up with marks on the engine. I turned the crankshaft 2 revolutions and rechecked the timing marks. All of the sprockets are in the correct positions but the alignment marks on the belt are not. Will this make a difference, is that normal?
