94 Trooper LS - Stereo wiring
Hello all,
I need some help in re-wiring the plugh to the OEM Fujitsu tape radio. Actualy I made a mistake with a few years ago, when I removed both, the OEM Fujitsu tape and Fujitsu CD-player, in favor of a 7" LCD (at the top of dash), and a DVDplayer (at the bottom of dash). Now, becouse of some quality problems, I decided, to reinstall the OEM Fujitsu tape radio, but.......... I dont remember what wires color, corresponds to OEM plug cell. The big mistake I made, was that I carefully removed wires from the OEM plug, instead to cut them. Thats why I lost the color arrangement in the OEM plug cells. What can help me the most, is a photo or two, of the origynal wiring placement in the plug. In my country (Romania), Isuzu Trooper is very rare, and without a good help from the forums, I will not clear up the trouble. Thanks in advance, 1994 Isuzu Trooper LS, 3.2 imported from USA. mwafrik@yahoo.com |
Originally Posted by waingroo
(Post 41244)
Hello all,
What do you mean MDKDRAGON?..........
Considering that my english is not perfect, a little bit of respect is enough. |
(Post 41255)
Considering that my english is not perfect, a little bit of respect is enough. Or maybe this will help: http://www.the12volt.com/installbay/...ard/Isuzu.html |
Originally Posted by MEphenSean
(Post 41269)
I think he means, "Are you serious?" because he can't believe that you are so concerned about putting an old, stock, cassette deck back into your truck in 2009. Really, I think there are many, many better options than any stock tape player from 1994. Cassette tapes are almost unheard of in the US now. I took the cassette player out of my 1995 Trooper a few weeks ago (the day I got it), and I will see if I can get a couple of pictures of it and the wiring harness that plugs into it, but it will take a few days. It might be the same, so hopefully that will help you a bit.
Not sure if it's the same but i found this one on the web.For 1999 isuzu trooper
Constant 12V+ Red/White Switched 12V+ Orange/Yellow Ground Black/Yellow Illumination n/a Dimmer n/a Antenna Trigger Brown/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) White Left Front (-) Red/White Right Front (+) Gray/White Right Front (-) Green/White Rear Speakers 5" Rear Pillars Left Rear (+) Yellow Left Rear (-) Blue/Yellow Right Rear (+) Orange Right Rear (-) Orange/Black |
| All times are GMT -5. The time now is 06:54 AM. |
